Thoughts about the HTTP headers
Hi, I have been using the new RW6 REST API for a while now and I think it works really well.
I was thinking that adding "Access-Control-Allow-Origin: *" to the response headers would improve the API since it would allow for webpages to fetch data from the robot controller without needing to be served from it. Furthermore; although the character encoding is specified in the XML document, this information is not present in the JSON response and could be specified in the HTTP headers as well.
Cheers!
  • Facing the same issue.
    Yep, that would pave the way for modern React JS apps.
    Creating a backend server in python or .Net backend to interface with the robot controller's REST interface feels really redundant, since the front-end can just as well consume the REST API.
  • Found the config file of the REST server running on the robot ( located: /hd0a/05-102162/Products/RobotWare_6.05.0129/system/appweb.conf). The server software used is EmbedThis.
    The conf file suggest that authentication is configurable / could be turned off.
    That said, I ran into changing the file; seems additional permission is required and the usual ABB pwd's didnt pan out here.
    <Route ^/poll>
    	AuthRealm "validusers@robapi.abb"
    	AuthType digest
    	AuthDigestQop auth
        WebSocketsProtocol  robapi2_subscription
        AddFilter           webSocketFilter
        SetHandler 			wsSubscription
        RequestTimeout      72hours
    #	InactivityTimeout   5hours
    	WebSocketsPing 		30seconds
    </Route>
    <Route ^\/fileservice(\/.*)*$>
    	AuthType digest
    	AuthDigestQop auth
    	SetHandler rapi_filehandler
    	Methods set ALL
    </Route>
    <Route ^\/docs(\/.*)*$>
    	AuthType digest
    	AuthDigestQop auth
    	AddHandler fileHandler
    	Methods set GET
    </Route>
    <Route />
    	AuthType digest
    	AuthDigestQop auth
    	SetHandler rapi_handler
    	Methods set ALL
    </Route>
