internal error 100000 with stationary tool
hi,
I’m trying to use a stationary tool with workobject on end of robot and I keep getting an internal error stationary tcp with user coordinated move not implemented
Do I need a power-pac or another option to enable stationary tcp with part mounted on robot or am I doing something wrong?
  • Is RobHold true for your workobject?  Next, is that workobject moved by a mechunit?  Should be no.
    Lee Justice
  • That did it I had the Programmed to false and mechunit setup as robot....
    unchecked that and works, thank you
