internal error 100000 with stationary tool
Mech
hi,
I’m trying to use a stationary tool with workobject on end of robot and I keep getting an internal error stationary tcp with user coordinated move not implemented
Do I need a power-pac or another option to enable stationary tcp with part mounted on robot or am I doing something wrong?
Is RobHold true for your workobject? Next, is that workobject moved by a mechunit? Should be no.Lee Justice0
That did it I had the Programmed to false and mechunit setup as robot....
unchecked that and works, thank you0
- 367 IRC5
- 858 RAPID Programming
