Recording simulation
Hi!
Is it possible to record your simulation in 5.07?
There is no such functionality built-in, but you could use a third party screen capture tool such as Camtasia.
regards,
Johannes
Johannes Weiman
thanks, I will take a look at that!0
I recommend Windows Media Encoder 9 series which records compact files directly to the WMV format.
http://www.microsoft.com/windows/windowsmedia/forpros/encode r/default.mspx
It would also be very nice to be able to save the simulation sequence as a file. Are there any plans to implement this feature in your future releases?
trauto2006-10-3 22:34:280
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
