RS doesn't recognize any RobotWare
I am having problems with RobotStudio, so I tried to uninstall all my RS versions, from 6.02 to 6.07 and make a clean reinstall of 6.07 only. Now RS is not showing any Robotware when trying to make a new offline system.
But I explore the folder and there are Robotwares.
And when I create an empty station, this appears in my log (sorry for the spanish).
"The name of the directory of the distribution package is not valid. Package hasn't been loaded".
Please I need help. I renewed my RS License and I need keep on working if simulations for new project.
Un saludokind regards,
Daniel Aguilar
Automation Engineering
  • Hola daguilar,
    Wich windows version are you using? also check out your login name, it may cause problems because some symbols are not recognizable.
  • Xma said:
    Hola daguilar,
    Hola Xma,
    I'm actually running W7 Professional SP1. What do you mean with login name? Windows user name? It's "daniel.SMARKTEC". I've been running RS for 3 years with no problems with this login name...
    Daniel Aguilar
  •  have you tried to install the package, from the Add-Ins tab (see below)
    For what? You need a downloaded package to install it, like RW 5.XX, not 6.XX
    Daniel Aguilar
