Pack&Go .NET exception.. license
Hello everyone,
I have recently received this message when I save and open Pack & Go files on my PC. I do not know what to do to fix the error, as everyone who receives my Pack & Go file gets the same or similar error messages. Even on the same computer as the file is generated on!
I'm using RobotStudio 6.07 on a Windows 10 64 bit. It should be mentioned that I am using a license from my university and that RobotStudio otherwise does not mention problems with the license.
I really hope someone can help me, Pack & Go is a feature that is a deal breaker for my project
Best regards
Manuel
RobotStudio .NET exception: Not a valid license file, license file extension shall be rlf
Base exception: ArgumentException
at Babel.Stub.Msil..(Int32 , Object , Object[] )
at LicenseManager.LicenseReader.ReadLicense(String licenseFilePath)
at ABB.Robotics.RIM.LicenseInformation..ctor(String licenseFilePath)
at RobotStudio.Services.Systems.SystemBuilder.SystemBuilderGandalf.AddLicensesFromBackup(String backupPath, ControllerSystem controllerSystem)
at RobotStudio.Services.Systems.SystemBuilder.SystemBuilderGandalf.<CreateSystemFromBackupAsync>d__15.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at ABBInternal.StationManagement.PackAndGoService.<CreateSystem>d__22.MoveNext()
at ABBInternal.StationManagement.PackAndGoService.<UnpackAndWork>d__19.MoveNext()
ParamName:
Hello,Is your licence valid in File - Options - Licensing - View installed licenses.. ?☑️2024 - RobotStudio® User Group0
Yes, all is ok..
Is there not anyone who has an idea about solving the problem? I have to say that I'm annoyed of Robotstudio (6.07.01), I spend more time solving problems caused by Robotstudio than just using it as intended.0
Please contact your local ABB office for support with this problem.Best regards,
Did you find what was causing this issue? I am running into the same issue.
Thanks,
Marcus0 -
The problem is not the RobotStudio license, but rather the license file that is required to create a (virtual) controller system.
From the message it looks like the backup in the .rspag contains unexpected files in the BACKINFO\license folder. What RobotWare version are you using?
Johannes Weiman
RobotStudio Team, ABB Robotics0
