Check if motion task is running in RAPID?
SydShore
Is there a RAPID command I can use within a non-motion task to see if a Motion task is currently running?
You can set up and monitor a system output TaskExecuting with an argument specifying the task name.Lee Justice5
Hello,You can use
IF RunMode(\Main)=RUN_CONT_CYCLE THEN
TaskExecuting is the ticket! Thank you lemster68!0
