How to copy/import the target points and path from one station to another ?
Best Answers
Synchronize to RAPID on old station, save the module out, load module to new virtual controller, synchronize to station.
5 -
Multiple modules in the virtual controller is okay but not with the same name or same named data -- it will save over modules, procedures, and program data (targets, work objects, etc.) that have the same name when you synchronize to RAPID. If you want to keep the previous data, it's easiest to right-click and save the module out of RobotStudio rather than renaming everything every time you synchronize to RAPID.
Post edited by soup on1
It worked. Thank you very much.Can I have two modules in one station ? Because I had to replace the (empty) module while loading the old module (with required target points and paths)0
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 25 AppStudio
