Profinet. Problem with connection
I have little problem with connection IRC5 with s7-1200.
In IRC5 i have installed cp1616 and 888-1 Profinet m/s option. I just configured my PLC, and IRC5 via RobotStudio, but still i have warning:
71429 - No configuration in the Profinet PCI board. In HOME catalog i have right configuration *. xdb file .
Has Someone similar problem ?
I have RW 5.15 on irb4400.
best regards
Pawel N.
best regards
Pawel N.
Hello, The CP1616 board can only be configured when the IRC5 is in the boot application. You must directly connect to the board and configure it with the siemens software as well as in the IRC5 parameters.0
- 858 RAPID Programming
