Updated Revolution Counter In Teach pendant / Flex pendant
Hi all, I updated revolution counter In Teach pendant for all 6 axis in IRB 1520 id Robot. Is it possible to get back old/previous revolution values with out labeling and markings on robot?
No you can not get back the old settings as it is setting the revolution counter for each motor to zero, which is not backed up.
The robot has markings in the casting for the rev counters, so as long as the robot was correctly calibrated before you did the update you can redo the update in the correct position.
1 -
Thank you sir.0
- 365 IRC5
- 84 OmniCore
