Missing color when import .sat-file
I have a problem when my colleague export a 3D-cad-fil from his Autodesk Inventor 13 to a Acis-file (.sat). All colors disappear when I import to RS 5.07. Is the problem the converting to .sat in Inventor or is it when importing to RS??
Best regards
Daniel
Best regards
Daniel
Hi Daniel,
There are a couple of different ways to specify colors in .sat, but RS should handle most of them. Perhaps if you could upload a small example file I could take a look at it.
Johannes Weiman
What is the easiest way to get you an example file??
Best regards
Daniel0 -
You can attach it to a forum post (if it's smaller than 2MB), or mail it to johannes.weiman(at)se.abb.com.
Johannes Weiman
Thanks for fast answers!!
My problem in this case was that the exported file from inventor did not have any information about colour to give to RS. Probably with CAD-converter the problem can be solved.
/// Daniel0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
