Saved Options selection
DavidLanham
in UpFeed
I work with RobotStudio every day and it seems like I am always selecting the same options that I know we always purchase with our robots for our customers when I am building my station from Layout. It would be nice if I could have a default set of options that I click and it would select all the same options that I always select.
Instead of building from layout you can export the options you've selected to a XML file by clicking the export button in the image if you use the installation manager.
You can then import the settings whenever you create a new controller. Alternatively you can also create from backups which will do the same thing.
Scott,Thanks, but that would not work with different size robots. Unless I create the same thing for each size robot right?�
I have added this to our backlog as a feature request.Johannes Weiman
Also, you can edit the file <installdir>\Template Systems\TemplateSystemsRW6.xml (for RobotWare 6.x).
Add the desired features under <BaseTemplate type="system" name="Base"> and they will apply to all system created from Layout. You can find the feature names in a created VC in the file internal\controller.rsf.
Johannes Weiman
Johannes,I really should check back with the forums more often. I did not see your post until today, but it worked great! Thank you very much.�
