Activating Safemove Safe Zone
PetrB
I've been trying to set up Safe move, but somehow I can make it active.
I follower the manual, set up robot geometry, tool geometry, safe zones, safe range, synchronization, written safety configuration to controller, rebooted, synchronized axis, validated and locked config, but still when I jog robot outside of work zone, it won't trip the safety.
Any ideas?
According to manual, zone is deactivated. But in control panel-safety controller-mode, controller is set to Safety Supervision Mode, is there any other setting, how to enable Safemove?• Green - Zone is deactivated• Yellow - Zone is active• Red - Zone is active and violated
Problem solved. I forgot to configure Tool Position Supervision and Safe Range Position Supervision.
If someone encounter same problem, here is solution.
Define Safe zone and Safe range, then right click on Safe zone/Safe range and add supervision. Manual Functional safety and SafeMove2 RW 6-en.pdf, page 156, 6.15 Configure the supervision functions.1 -
hello, could you please tell me where could I get the manual from ?0
Lee Justice0
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
