Physical FlexPendant and RobotStudio
There's no way to connect a FlexPendant to a PC at this time.
Out of curiosity, why would you need such a feature for?
We also have thought of doing this for training.
While the virtual FlexPendant is good it would be better/more realistic to be able to use a real FlexPendant.
I presume an adapter box would be needed to break out the ethernet connection and supply 24 VDC to the FlexPendant...
I would like to try it for training.
I just want to make training more realistic in situations when no access to any real robot. Plus we can use VR also. This combination should be much more exciting and effective.
At least in my opinion.
FANUC, for example have some PC-Kits for this.
Don`t sure about KUKA yet.
I removed your duplicate message. There is supposed to be a cog wheel on the right of the post, below the time of the post. Click it and choose remove.
I've moved this thread to the upfeed section of the forums, as a suggestion.
Hi, I have similar question like virge. Task is to upgrade basic robot training by using RSO. Thanks0
Is there any update or current plan to develop this capability?
I've spoken to RobotStudio R&D and they've said that there's an on-going project (developed by another team in ABB) to make this functionality a reality in the near future.
That is all the information I have at this time.
Hello everyone,
I've received more information regarding this project and it turns out that the item developed will only be available internally within ABB.
You could contact your local ABB (via https://new.abb.com/contact-centers) and forward your request for this item so that ABB perhaps decides to make a product out of this item (make it externally available as well).
This would be great robot education!-----------------
David
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 33 AppStudio
