INSERT PHOTO IN ROBOTSTUDIO
Could I insert photo in robotstudio simulation? if yes How?
Yes, you can apply images to geometry (texture) and markups:
Johannes Weiman
Thank you so much for your answer, could you tell me how could I insert the image and in which format the image should be ?0
Thank you, now I can insert it, I will test it and get back to you because the image is always huge when I use markeup0
it is great, Thank you again, it is working with texture0
