Difference in Simulation speed between 2 robots
c63amg
I am simulating a multi robot cell, and the robots are simulating at different speeds. They are programed at the same speed.
I have already confirmed the controllers for each are reading 100%.
The simulation is set at 100% in the simulation settings.
Where else can I control simulation speeds?
how big is the difference and which robots are you using?0
Are the robots of the same specs? In other words, the same type of robot with the same reach?Best regards
Alexander Källberg0 -
Are the two robot using the same load data and tool data ?Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
Any velsets or accsets in programs? Also, any arm load?Lee Justice0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
