Suggestion (or question): Copy/paste "target data"
Sometimes I miss the ability to copy and paste the position and rotation of a target in relation to it's parent.
Example:
-Two identical fixtures
- Each has a wobj and a robtarget wFixt1 and pFixt1 (and wFixt2 and pFixt2)
- after modpos of pFixt1 in wFixt it would be nice to right-click pFixt1 and "copy target data" and then right-click pFixt2 and apply "Target data".
Maybe there is already another way of doing this?
/David
  • graemepaulin
    graemepaulin ✭✭✭
    edited October 2018
    Hmm can not get the snip to attach or insert...
    Had to switch to Chrome from IE to get it to work!!??
  • graemepaulin
    graemepaulin ✭✭✭
    edited October 2018
    You can select copy to workobject from context menu (when you right click on the target).
  • DenisFR
    DenisFR ✭✭✭
    Would be great to have "Copy to RAPID Format". So you can paste formatted text in your RAPID code.
  • You can select copy to workobject from context menu (when you right click on the target).
    That's a nice feature but I rarely use this because it creates a new target. In most cases I already have my program with e.g. pFixt1 and pFixt2 declared in RAPID code.
  • DenisFR said:
    Maybe this is harder because a robtarget has more information than the target has, RobConf etc?
  • DenisFR
    DenisFR ✭✭✭
    Or at least as Pose.
    And Paste from RAPID text too.
    Not only for Pose but for lot of types.
