Suggestion (or question): Copy/paste "target data"
Sometimes I miss the ability to copy and paste the position and rotation of a target in relation to it's parent.
Example:
-Two identical fixtures
- Each has a wobj and a robtarget wFixt1 and pFixt1 (and wFixt2 and pFixt2)
- after modpos of pFixt1 in wFixt it would be nice to right-click pFixt1 and "copy target data" and then right-click pFixt2 and apply "Target data".
Maybe there is already another way of doing this?
/David
Example:
/David
Hmm can not get the snip to attach or insert...
Had to switch to Chrome from IE to get it to work!!??
You can select copy to workobject from context menu (when you right click on the target).
.0 -
            Hello,Would be great to have "Copy to RAPID Format". So you can paste formatted text in your RAPID code.☑️2024 - RobotStudio® User Group0
That's a nice feature but I rarely use this because it creates a new target. In most cases I already have my program with e.g. pFixt1 and pFixt2 declared in RAPID code.graemepaulin said:You can select copy to workobject from context menu (when you right click on the target).
.0
 - 363 IRC5
 - 81 OmniCore
 - 853 RAPID Programming
 - 31 AppStudio
