Robotware 5.12 installation
I have tried to download robotware 5.12.04 into robotstudio 6.07. The installation works and the two files show up in the mediapool. However, when I try to create a new system robotware 5.12.04 doesn't show up as an option. I tested the same process with robotware 5.61. The files are in the same place as 5.12. However, 5.61 does show up as an option when creating a new system. Here is the screenshot showing the files in mediapool.
  • Are you using the system builder or installation manager?  Try system builder if not.
    Lee Justice
  • Hi,
    The supported RobotWare versions when creating a VC are:
    - System Builder - all 5.x versions
    - From Layout - 5.15 and higher
    - Template systems (New System and Solution with VC) - 5.6x and higher
    So for 5.12 you must use System Builder.
    Johannes Weiman
    RobotStudio Team, ABB Robotics
