How to switch to automatic mode
IRB 14000 Yumi
When I try to run programs in automatics mode, I always get the following error message on the FlexPendant:
Start failed. The operation was rejected by the controller safety access restriction mechanism.
What should I do to enable automatic mode for Yumi?
Hey @xzxben, could you plese give us more informations (or images) about your problem?The XS9 safety socket is correctly connected?Do you have any errors in your program?Are you using system input signals to start/stop the execution?Are you able to swich from manual to automatic or change the motors state?Maybe this lots of questions could help us to identify your problem.
U.0 -
Thank you. I didn't connect anything to XS9. What should be done with it?Programs are fine.I didn't use I/O signals.I can change manual to automatics mode and the motors state.0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 33 AppStudio
