Speedrefresh command used in Multitasking
i need support to configure speedrefresh command in multitasking,
i have configured the command  in multitasking but it showing error of 40813-execution error.
the task not configured for mechanical unit.
and it is showing remedy to change the configuration or remove the speedrefresh command.
Please help me out.
Thanks in advance.
  • soup
    soup ✭✭✭
    SpeedRefresh only works in a motion task. The manual shows an example of updating the speed with a trap from a signal. Try adding a trap and updating the speed via a signal or shared PERS between the motion and background task.
  • i have done with trap routine speed is also updated but not the updated override is not showing on flex pendant
  • The speed on the teach pendant is not indicative of the speedrefresh.  They are separate overrides.
    Lee Justice
  • sir please suggest how can i identify the speed override is updating during robot executing the motion command.
  • soup
    soup ✭✭✭
    Good question -- I am only aware of CSpeedOverride which I believe only tells you that the operator overrode the speed via the pendant but not via RAPID with SpeedRefresh...
  • could you upload again that manual? The link is broken
