Problem about Boot Application
I was going to download a new system to the controller(IRC5) via “System Builder” in RobotStudio 6.07. But it showed “there is not enough space on it”.
I searched on the Internet and someone suggested that I can delete the current system in the controller. So, I deleted the old system.
Then I tried downloading my system and it was successful.
Then I clicked on the “yes” button to restart the controller. However, I took me to the boot application showed on the FlexPendant, like this:
Then I clicked on “Select System”, I cannot see the downloaded system which was showed has downloaded successfully in RobotStudio.
I tried to download from RobotStudio again, it showed that “not enough space” again.
I also tried to make a boot media from the backup to a USB stick to install it, the problem was still “not enough space”.
Overall, at the moment, I cannot download a system, I cannot delete a system, I cannot do anything. What I can see is just this browser after restarting the controller.
Could someone tell me what I can do to solve this? Thank you very much!
Is the controller able to run RW6.xx?
If it is an older system with the older main computer you have to use RW5.xx.
Hi graemepaulin, thank you very much.
I am not sure if the controller is able to run RW 6.xx.
The version of RW I used is 5.13.4001.04. My RobotStudio version is 6.07. Is it OK?
Thank you again!
Yes this is OK
Have you powered off the controller, wait 30 seconds or so then power on again?
Yes, I think I have done this. I powered off the controller last Friday and I powered on today. Actually, I tried this several times last week. Thank you so much. What else can i do?0
Please ring the New Zealand ABB contact center on 0800 464 222 and ask for me (Graeme Paulin)
1 -
OK, sure. Thank you very much!0
Hey there,
Did you solve this problem?
I'm in the same situation!
- 341 IRC5
- 68 OmniCore
- 839 RAPID Programming
- 18 AppStudio
