Using tables in WWServer [WebWare Server]
in WebWare
a customer likes to write data from one robot to a custom database?
Is it possible to use two tables from one robot? How do I have to switch between the tables in my RAPID code.
Hello Kevin,
Yes it is possible to write to multiple tables. To do so, simply adjust the SCWrite command to direct the data to the correct table. For example:
SCWrite MyTableRec;
SCWrite MyTable1Rec;
I have attached a modified version of the sample custom db module contained in the WebWare Server User's Guide that creates and writes to two tables.
Note: this sample also requires WebWare.sys to be installed on the controller. RussD38068,7680208333Russell Drown0
- 367 IRC5
