cross connection
Merced
What is a cross connection?
Hello,It's like if you're programming your io signal.From System parameters documentation:
Type description A cross connection is a logical connection between I/O signals of type digital (DO, DI) or group (GO, GI), that allow one or several I/O signals to automatically affect the state of other I/O signals.
Usage Using cross connections is a simple way to interconnect I/O signals and let the robot system handle I/O activity without having to execute any RAPID code.
Cross connecting I/O signals is a good alternative if there is an input I/O signal in the process that, when activated, automatically activates one or several output I/O signals.
It is also possible to construct more complex conditions by combining up to five different actor I/O signals with operators. The actor I/O signals can also be inverted.
thanks man0
Have you worked with Safemove2 and CIP Safety
Hello,No, only with direct ProfiSafe, no CIP.☑️2024 - RobotStudio® User Group0
