Event error Code to PLC
Hello
I want to send the error code of the event message occured to PLC, Im talking about ERRORID, is it possible? what variables should i use? because ERRNO type ERRNUM couldnt help, im looking for event errors.
Thank you.
  • Read up on errtype, maybe it will do for you what you are asking.
    Lee Justice
  • Whoops, that is the data type, instruction is: ReadErrData.
    Lee Justice
