Reset DO signal Cross-connection
I would like reset dosignal1 according condition other "dosignal2=1".
Becauase in Cross Connection I can only Set signal as "Resultant", not possilbe reset.
And In initial state a need both signals as 0.
It is possible, how?
Thank you in advance
Jiri Muller
  • Maybe make another cross connection, same signals but invert to do the reset.  Set a default value of 0 in the signal configuration.
    Lee Justice
  • I
    I tried it, unfortunately it is not possible....  :/
    Actually I need close to the valve via PLC by pulse signal from robot...
  • So then, try another signal, virtual even, cross connected to the resultant and invert it.
    Lee Justice
