Difference in Simulation speed between 2 robots
I am simulating a multi robot cell, and the robots are simulating at different speeds.  They are programed at the same speed.
I have already confirmed the controllers for each are reading 100%.
The simulation is set at 100% in the simulation settings.
Where else can I control simulation speeds?
  • how big is the difference and which robots are you using?
  • Are the robots of the same specs? In other words, the same type of robot with the same reach?
    Best regards
    Alexander Källberg
  • Are the two robot using the same load data and tool data ?
    Regards
    Knud Erik Lindberg
    Danrobotics
  • Any velsets or accsets in programs?  Also, any arm load?
    Lee Justice
