Reset DO signal Cross-connection
I would like reset dosignal1 according condition other "dosignal2=1".
Becauase in Cross Connection I can only Set signal as "Resultant", not possilbe reset.
And In initial state a need both signals as 0.
It is possible, how?
Thank you in advance
Jiri Muller
Jiri Muller
Maybe make another cross connection, same signals but invert to do the reset. Set a default value of 0 in the signal configuration.Lee Justice0
I
I tried it, unfortunately it is not possible....
Actually I need close to the valve via PLC by pulse signal from robot...
So then, try another signal, virtual even, cross connected to the resultant and invert it.Lee Justice0
