virtual flexpendant is completely white.
We have migrated from windows 7 to windows 10 and now that I open a system in RS 6.08 the flex pedant is completely white.
I got several different systems from backup (spot, glue, handling) and I also loaded PnG which I had done before the migration, has also tried to make GoOffline from RS when you are connected to a real controller, but the window on flex pedant is still white .
The RobotWare we have is 5.13.04 and 5.13.05.
Also tested with RS 6.05, RS 6.06, RS 6.07 but same problem.
We have some robots with RW 6.06 and if I make a system from backup on these, then the pedant work ! I'm going crazy.
Need to make it work, does anyone have an idea what can be wrong?
mvh / Jonny
This could be caused by a missing Visual C++ dependency. Ensure that you have this installed:
https://www.microsoft.com/en-us/download/details.aspx?id=5555
Johannes Weiman
RobotStudio Team, ABB Robotics6
Yes, that was the problem.
I got my laptop back a few days ago from the IT department and they had found this problem and installed Visual C++ 2008 Redistributable and now it works.
But thank you for this answer.
输入你的评论I have the same situation, but when I install visual studio, the system always says that I have installed the updated version, but I still report an error after I uninstall it. May I ask if there is any way to fix it?0
- 88 OmniCore
- 42 AppStudio
