IRB2400L in RS 6.08
h.esk60
You can manually import that model by clicking "Import Library" menu. The file is located at following folder.
C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio 6.08\ABB Library\Robots
Hi, I also have the ABB IRB2400L. Specifically we have the old SC4 plus controller with the orange ABB IRB2400L. You can find the model in the ABB library and "others" folder. However, I cannot install the IRC5 virtual controller with RoboWare 6.08.00.00 is not compatible with this model. Did you find any solution?
You will need to use a 5.xx RobotWare as the many of the older models were not ported to the new 6.xx RobotWare.
- 367 IRC5
- 858 RAPID Programming
