Virtual signals
garre
Hi!
I have a problem. When I try to create my own unit in RobotStudioOnline and connect it to Virtual1 it doesn't appear. I can create it but it won't appear under Virtual1 under I/O systems.
Why?
I noticed this can happen if you forget to set "Type of Unit". Also don't forget to restart the controller
Johannes Weiman
Hej!
I'have filled in all information but it won't appear. I also restarted (warmstart) and even restarted the RS and RSO.But still the same problem... Ideas?
- 87 OmniCore
