Index through robtargets
scottMHA
is it possible to index through robtagets in a FOR statement? See example below, the argument Pick+i should reference the robtarget Pick1, Pick2 etc....
CONST robtarget Pick1;
CONST robtarget Pick2;
CONST robtarget Pick3;
CONST robtarget Pick4;
FOR i FROM 1 TO 4 DO
Pick i, Pick+i;
Drop;
ENDFOR
ENDFOR
PROC Pick(num PickNum,robtarget pickLoc)
MoveJ RelTool(pickLoc,0,0,200),vmax,z10,t_Gripper_16;
MoveL pickLoc,vmax,fine,t_Gripper_16\WObj:=wobj0;
Put your robtargets into an array. Make a separate routine so you can make touchups or you have to view in the data to modpos them.Lee Justice0
you could use the instruction GetDataVal to retrieve the required robtarget.Proc Pick(string Name, num Index) var robtarget pTemp; var string stName; stName:=Name+Valtostr(Index); GetDatval stname, pTemp; MoveL pTemp,...; endproc
/BR
Micky2
- 344 IRC5
- 70 OmniCore
- 842 RAPID Programming
- 19 AppStudio
