Deleted
NicolaB
Error
Post edited by NicolaB on
Hello,You should use AliasIO in you case.
VAR string sVarValue:="8";To set input, you can use Cross Connections.
VAR string sVarName:="goTest";
VAR signalgo goAlias;
VAR num nValue;
IF StrToVal(sVarValue, nValue) THEN
AliasIO sVarName,goAlias;
SetGO goAlias,nValue;
ENDIF
☑️2024 - RobotStudio® User Group0
