Error using UAS in rs
I have made a test with UAS. I made on ADMIN user with full acces and then removed all rights on Default user. After that i logged of and i cant find any user exept for default user. And defalut user has no rights at all. Then i made a coldboot on the controller but can stil not get acces. Then i deleted the system and made a new on. Stil cant get access. I have reinstalled RS again but cant get access to any of System og get in to the UAS administration menu.
Please help i cant workimageimageimage
2006-10-26_001729_uas_usersgroups.zip
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Hi Klaus,
    Try this:
    Shut down RSO.
    Delete (or rename) the file called "uas_users.xml" that is placed in the folder C:Documents and SettingsAll UsersApplication DataABB Industrial ITRobotics ITRobVC .
    When you start up RSO again you will only have the "Default User" left, with full access.
    ABB Robotics
  • After deleting al of the xml files in dir it works.
    Thanks for your help
    [QUOTE=Anders S]
    Hi Klaus,
    Try this:
    Shut down RSO.
    [/QUOTE]
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
