Error using UAS in rs
I have made a test with UAS. I made on ADMIN user with full acces and then removed all rights on Default user. After that i logged of and i cant find any user exept for default user. And defalut user has no rights at all. Then i made a coldboot on the controller but can stil not get acces. Then i deleted the system and made a new on. Stil cant get access. I have reinstalled RS again but cant get access to any of System og get in to the UAS administration menu.
Please help i cant work
2006-10-26_001729_uas_usersgroups.zip
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,
Try this:
Shut down RSO.
Delete (or rename) the file called "uas_users.xml" that is placed in the folder C:Documents and SettingsAll UsersApplication DataABB Industrial ITRobotics ITRobVC .
When you start up RSO again you will only have the "Default User" left, with full access.
After deleting al of the xml files in dir it works.
Thanks for your help
[QUOTE=Anders S]
Hi Klaus,
Try this:
Shut down RSO.
[/QUOTE]Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 367 IRC5
- 858 RAPID Programming
