System installation/ cold start
yazan
Usually when installing a software it required to perform a cold start, and this can be chosen from the teach pendant, I have an IRB6400 M99 S4C controller, but the issue here is that it has no software so I can't perform a cold start from the teach pendant, how can I do it in this case? or is it a normal start considered a cold start in this case?
Thanks for your help,
Yazan
Yazan
If the memory is empty the controller will do a cold start on boot up (goes through self tests then asks for the key disk, etc).
Hi Graemepaulin,
Thank you so much for your reply.
Yazam0
