workobject userframes?
Can anyone explain why when rotating the userframe portion of a workobject it seem to rotate in the base frame instead of locally.  Is there something that i am doing wrong or is that just the way it is.
RUSSELLgee
Director
1/118 Connaught St Sandgate QLD Australia 4017
ph +61738694298
fax +61738693284
mob +61418116644
email russell@manmac.com.au
  • Hi,
    If you have selected Reference Local it should rotate locally. If you explain more in detail how you rotate, maybe I can find out what goes wrong for you.
    ABB Robotics
  • I was trying to rotate the workobject uframe.rot while the transform values were 0, the transform values were in the object frame. I have since put the transform values into the uframe and fixed the problem.
    RUSSELLgee
    Director
    ph +61738694298
    fax +61738693284
    mob +61418116644
  • Hi people.
    I have the same problem that RussG but i don't understand how he have corrected it.
    In this moment, i make the rotation in the base but i need to compensate X Y Z to make a rotation locally.
    Sorry for my english...
