How to rotate axis 6
Dear,
In my program I have to rotate axis 6 180 degrees counter clockwise and then back 180 degrees clockwise.
Is there a command to do this or is this done by rotating points orientations ?
Thanks in advance for the help greetings.
  • lemster68
    lemster68 ✭✭✭
    MoveAbsJ
    Lee Justice
  • MoveJ p10,vmax,z10,tGrip,\WObj:=wobj0;
    MoveJ Reltool(p10,0,0,0\Rz:=180),vmax,fine ,tGrip,\WObj:=wobj0;
  • lemster68
    lemster68 ✭✭✭
    This will work if your TCP is directly in line with axis six and it has the same orientation.
    Lee Justice
    Thanks for the help.
