Arcweld powerpac, Merge paths
Is there any way to merge paths?
i tried to merge them in rapidcode, but that didnt apply with arcweld powerpack.
And "sync to station" didnt solve it either. I found out to late when i was programming that i could cut down the number of paths from 8 to 3.
Iknow it is possible to do it in rapid, but i want to be able to open the program and edit it in arcweld if neccesary.
i tested exporting paths to .xml and looking at the code but it was to overwhealming
  • Okay somehow i solved it. I think it was becaus i merged them in rapid. becaus pth1, 2 & 3 contained all paths and all i had to do was to delete the others :) so this is solved
