Targets doesn't follow its reference coordinate
Hi guys,
I am new to RobotStudio. I have a little problem with the targets. I have a workpiece that amounted on a positioner and I set the UCS frame on the axis of positioner. Then, I created several targets with reference to my UCS frame. But when I jog the positioner (my UCS is rotating), the targets don't move with respect to UCS. Does anyone know how to solve this problem?
Sincerely,
Xirui
Sincerely,
Xirui
You would have to specify that the workobject is moved by the mechanism. In your MOC under the mechanical unit it should say "allow_move_of_user_frame" and in the workobject definition it should have the name of the mechanical unit.Lee Justice5
lemster68 said:You would have to specify that the workobject is moved by the mechanism. In your MOC under the mechanical unit it should say "allow_move_of_user_frame" and in the workobject definition it should have the name of the mechanical unit.
Forgive me for asking these stupid questions. Thank you again and looking forward to your reply.
MOC.cfg is your motion configuration file, it is found in syspar in a backup. But you can use the pendant, control panel, configuration, type=motion find mechanical unit and find allow move of user frame, need to set to YESLee Justice1
In the offline/3D case, you must create a Workobject that is moved by the positioner. Then create the targets in that workobject.
Johannes Weiman
Johannes Weiman said:In the offline/3D case, you must create a Workobject that is moved by the positioner. Then create the targets in that workobject.0
Did you do the other step with your MOC? Allow move of user frame.Lee Justice0
lemster68 said:Did you do the other step with your MOC? Allow move of user frame.
Thank you very much anyway. Your comment helps me learn many new things.-1
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
