Failed to install RobotStudio 2019
Hello!
I just tried to install RobotStudio 2019. It failed with the following message:
It says "Database: Transformation: One row is missing and could not be updated. Table: Feature."
After clicking OK the Installation is aborted. No changes were made.
Are there known issues upgrading from 6.08. ?
The exact old Version is 6.08.8307.1040 on a Win10 Enterprise Version 1703, Build 15063.1839.
The folders for User documents, solutions, screenshots and screen records are changed from standard.
No further changes.
Regards
Michael Kobbeloer
  • There was a problem with installing in non-English language but that should be fixed now.
    Try downloading again or select English language in the installer.
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • OK, I will try it again. This will take a few days.
    I have to download at home because our internet connection here at work is way too slow for the 2.4 GB...
  • As I said, you can also select English language in the installer.
    Johannes Weiman
  • Yes, you are right! It works well with the English language.
    Thanks for advice.
