How to change mode from MANUAL to AUTO with a Keyless controller?
Luxrobotic
Hi everybody,
I'm currently installing an IRB2600 Keyless robot, and I'm wondering if it's possible to make the change of mode frome MANUAL to AUTO by setting an Input?
Regards
Cornet Raymond
Manager
LUXROBOTIC programming Sàrl
+352 621 354 570
raymond.cornet@luxrobotic.com
http://www.luxrobotic.com
PC HP ZBook 17 G3
intel Core i7 6700HQ 2.59 GHz
RAM 16GB
HDD 1TB
NVIDIA Quadro M1000M
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
Hi everybody,These options are installed in the system :I tried with configuring this SysInput :-Signal "diPN_Bit_6_AckAutoMode" -Action "AckAutoMode" -Arg7 "T_ROB1"But nothing happens when activated.any idea?
Regards
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
NVIDIA Quadro M1000M0 -
The only controllers that I have seen without keys still had a switch, just no key.Lee Justice0
Hi,finally we found the solution, by using the following SysInput :-Signal "diPN_Bit_5_AckAutoMode" -Action "AckAutoMode" -Arg7 "T_ROB1"
-Signal "diPN_Bit_7_RemoteOpModeEnable" -Action "RemoteOpModeEnable"\
-Arg7 "T_ROB1"
-Signal "diPN_Bit_6_OpModeReqAuto" -Action "OpModeReqAuto" -Arg7 "T_ROB1"
-Signal "diPN_Bit_8_OpModeReqManual" -Action "OpModeReqManual"\
-Arg7 "T_ROB1"But now, I'm facing the problem with the Emergency stop reset.I configured this SysInput :-Signal "diPN_Bit_9_ResetEmergencyStop" -Action "ResetEstop"
But I get this error message when I set it :20148: Confirm rejected
Description
Emergency Stop reset confirm, via System IO, was rejected.Any idea?Thanks
Regards
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
Ensure that the runchain has been reset first.Lee Justice0
HI,now everithing's ok. We were just trying to reset the ES and set the MotorOn while the robot was in Manual mode.It needs to be in Auto mode !Thanks anyway.Regards
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
I hope you have high safety standards. An accidental switch to auto could harm someone.
- 341 IRC5
- 68 OmniCore
- 839 RAPID Programming
- 18 AppStudio
