Suggestion: Rename Module including changing module-name inside the module-file
If you change the name in the first line and save the module, it will be renamed (if it's in a Rapid task).
But I agree that there should be a command also and have added an this to our backlog.
Regards,
Johannes
Post edited by Johannes Weiman onJohannes Weiman
RobotStudio Team, ABB Robotics5
Hi Johannes,Is there a hope that you can quickly extend the Rename function or otherwise install a solution in RAPID for renaming modules?
We need this very often:
Master module with type-dependent positions and constants, new unknown type number is coming, now the master module has to be copied and renamed via RAPID.Thnak youDaniel
Hi Johannes,2019 "But I agree that there should be a command also and have added an this to our backlog"We still need to copy and rename .mod-files via code-call. Can you update the RENAME-function please, to rename not only the filename of .mod-files but also the header-line. Thank You
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
