change Aprox. max in analog output
<div>hello! i need to change the Approx. max on my analog output AU_TCP , i need ich to be 1E 04 like the other one on the pic</div>someone to help?<b><i></i></b><i></i>
  • DenisFR
    DenisFR ✭✭✭
    It's defined in your EIO.cfg file or in Configuration - I/O System - Signal.
    Check Maximum Logical Value of your AO_TCP signal.
