Question on axis configurations
I am having some issues with axis configurations. If I use anyone of the available options in the configuration tab of each point it gets an error when simulating. If I go into Rapid Robtarget and edit them to a different value they work. One of the moves in question at the 2-3 second mark in the video linked below. The point is driven from a generic RobTarget that is populated with the correct target info based on the variable for the pallet number. code below. Any ideas? TIA
https://youtu.be/BM8dVJjZKTQ
 PROC main()
        Pno:= 1;
        LoadPalletLS2;
        Pno:= 3;
        LoadPalletLS1;
        Pno:= 12;
        LoadPalletMachine;
        Pno:= 16;
        UnloadPalletMachine;
        Pno:= 18;
        UnloadPalletLS2;
        Pno:= 29;
        UnloadPalletLS1;
PROC LoadPalletLS2()
        SetPno;
        PickPalRack;
        MoveL offs(LS2,0,75,0),v1000,fine,NSR160\WObj:=Shelves;
        MoveL offs(LS2,0,0,0),v1000,fine,NSR160\WObj:=Shelves;
        OpenGripper;
        MoveL offs(LS2,0,0,60),v1000,fine,NSR160\WObj:=Shelves;
        MoveL LS_Home,v1000,fine,NSR160\WObj:=Shelves;
 PROC SetPno()
        GetDataVal "Pal_"+ ValToStr(Pno), Point1;
        IF Pno >= 1 AND Pno <= 15 THEN
            PR_Home := PR_Home1;
        ENDIF
        IF Pno >= 16 AND Pno <= 30 THEN
            PR_Home := PR_Home2;
        ENDIF
PROC PickPalRack()
        OpenGripper;
        MoveL PR_Home,v1000,fine,NSR160\WObj:=Shelves;
        MoveL offs(Point1,0,0,60),v1000,fine,NSR160\WObj:=Shelves;
        MoveL offs(Point1,0,0,0),v1000,fine,NSR160\WObj:=Shelves;
        CloseGripper;
        MoveL offs(Point1,0,75,0),v1000,fine,NSR160\WObj:=Shelves;
        MoveL offs(Point1,0,75,705),v1000,fine,NSR160\WObj:=Shelves;
  • EricH
    EricH
    edited August 2019
    Maybe you didn't use the hook to show all available configurations? It is called "Include Turns".
    BTW: your robot can work more efficient with zones.
  • you could also use confL\off for the part of the path that is causing issues (turning back on (confL\on) normally when you are away from obstructions and probably with a MoveJ so the axis can reset)
