How to temporarily stop PP without using "fine" zone?
egor
My first try doesn't work... Robot stops at WHILE loop.
TriggIO Trig_Pos_Reached,50\DOp:=do_Pos_Reached,1;
!do_Pos_Reached set high 50 mm before point "p1"
TriggL p1,v300,Trig_Pos_Reached,z50,VacuumGrip;
WHILE do_Pos_Reached=0 DO
TPWrite "PP inside";
ENDWHILE
This second try, but it's still working badly:
MoveLSync p1,v300,z10,VacuumGrip,"PP_Catcher";
Maybe it's possible to use only MoveLSync instruction, but I can't understand how to hold PP in WHILE loop until the robot reaches point "p1".
ENDWHILE
PROC PP_Catcher()
ENDWHILE
While CRobT() <> p1 DO
blah blah
EndWhileLee Justice0 -
Where is the next point? You could factor in the z50.pzone_tcp, might have to throw in the Dist() function.Lee Justice0
lemster68 said:Where is the next point? You could factor in the z50.pzone_tcp, might have to throw in the Dist() function.
ENDWHILE
!Some Logic expressions
TriggL p2,v300,Trig_Pos_Reached,z50,VacuumGrip;
You could also try to substitute stoppointdata for the zone, might have to create your own to satisfy what you need to do.Lee Justice0
lemster68 said:You could also try to substitute stoppointdata for the zone, might have to create your own to satisfy what you need to do.
I tried to create my own stoppointdata:
PERS stoppointdata my_stopPoint:=[3,TRUE,[0,0,0,0],0,0,"",0,0];
But, robot still waits for a period of time... What am I doing wrong?0 -
Egor,
Between your original post about when a TRAP routine is executed and the PP being halted, could you please explain (without references to RAPID code) the job the robot is endeavoring to accomplish?
Further, is this a multi-move system? That question is posed because the WaitSyncTask instruction was used, which is not of much value (IMO) in a single manipulator system.
Use inpos to start with, it looks like you used a fllwtime type and zeroed the follow time. Inpos20 or make your own.Lee Justice0
Another approach would be to create a function that returns TRUE when the robot is near the position, refer to the Dist() function I mentioned earlier. Pseudocode follows:
While NOT fDistanceCheck DO
Blah
Blah
Maybe your motion...
ENDWHILE
FUNC bool fDistanceCheck
IF Some code here to evaluate CRobT() Dist() to end point
RETURN TRUE
ELSE
RETURN FALSE
ENDIF
ENDFUNCLee Justice0 -
SomeTekk said:Egor,
Further, is this a multi-move system? That question is posed because the WaitSyncTask instruction was used, which is not of much value (IMO) in a single manipulator system.0 -
lemster68 said:Use inpos to start with, it looks like you used a fllwtime type and zeroed the follow time. Inpos20 or make your own.
PERS stoppointdata my_stopPoint:=[1,TRUE,[20,20,0,0],0,0,"",0,0];
....TriggIO Trig_Pos_Reached,50\DOp:=do_Pos_Reached,1;TriggL p1,v300,Trig_Pos_Reached,z0\Inpos:=my_stopPoint,VacuumGrip;
MoveL p2,v300,z50,VacuumGrip;0 -
At at cursory glance it seems you might wish to investigate Option 624-1, Continuous Application Platform.
I have had zero experience with CAP, but the objective you seem to be interested in achieving suggests, to me, it may be of some help.0 -
egor said:SomeTekk said:Egor,
Further, is this a multi-move system? That question is posed because the WaitSyncTask instruction was used, which is not of much value (IMO) in a single manipulator system.Lee Justice0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
