Disable manual 100% function
I am not sure how to disable completely but you can limit/restrict with some coding as a event routine.
You can insert a loop in that event that waits for the robot to go to another mode to continue.
Something like this.WHILE OpMode()=OP_MAN_TEST AND CSpeedOverride(\CTask)<=100 DOTPErase;TPWrite "Switch to Manual or Auto mode";WaitTime 1.0;ENDWHILE
Also have a look at OpMode() in the Technical reference manual - RAPID Instructions, Functions and Data types.
So, just to be sure, you mean Manual Full Speed, not normal teach mode at 100% override?Lee Justice0
And do you have multi tasking?Lee Justice0
