Arcweld powerpack
Is there a reason powerpac always put MoveJ infront of ArclStart?
I prefer to use MoveL since it is more reliable and dont do any suspicious movements like the moveJ.
Cant seem to find any solution other than changing it afterward. So if anyone know how pls let me know or tell me a good reason why i should use MoveJ instead.
Thnx / Mike
  • Robotdude
    Robotdude
    Answer ✓
    Solved it, i post a picture if someone else ever have the same question :)
    Skriv din kommentar
  • Are you using ArcWelding to do the welding programming? If you do, check your Application Template which you use for that weld, and set the correct parameters inside the General Instructions tab. On mine I can set it as MoveJ or MoveL approach and depart parameter.
  • Yes i use Arcwelding to do the programming.
    Do you mean this window? or do i find the app tmeplate somewhere else?
