External axis wizard wont recognize my custom mechanism
k_schmid
What could be wrong if external axis wizard wont recognize my custom mechanism (external axis)?
If I build my system with a similar mechanism and swap it out in edit mechanism all is fine.
hi,.rslib uploaded here, just trying to see if there is somethig wrong with it since using to coordinate the base frame deastroys teh station controler
Still trying this...
I upgraded to version 2019.2 and still nothing.Working around by swapping an abb positioner but I dont like it.Since nobody else seems to have this I must be doing it wrong...Is this silent video for real the only documentation out there
Alright, i have a 2 axis positioner and I can only compile to "robot" not external axis. Does that matter?Can I change it? I can change it later but that wont help.0
Works with a simpler version (just 1 rotational joint), but not when I add the second prismatic one.Are there known limitations for external axis wizard? Are they documented somehow?Post edited by kschmid on0
Fine in robotware 6.07 broken above https://forums.robotstudio.com/discussion/11581/robotstudio2019-issues-and-resolutions#latest
I noticed it is still missing single and single types values. Is that expected?
Its a robot internally, in 6.07 that still seemed to work
https://forums.robotstudio.com/discussion/11581/robotstudio2019-issues-and-resolutions#latest apparently know already
https://www.youtube.com/watch?v=s1Vk-xUDGy4
