Rapid program from a drawing.
svoldgaard
I have seen a lot of robots draw different drawings. e.g Homer Simpson.
Does anyone have a program to convert a drawing to a rapidprogram, so it is possible to make the robot draw what you want?
Thanks for the answer. It's a start.
But I was hoping for something, where I could import a drawing. e.g a jpg file.
Then it would create the rapid code from that.
and ideally something that could use moveC and Zones for better accuracy.0
